Home > Other Site Sponsors > English braid winch ropes available |
sparkylee Member Since: 06 Nov 2010 Location: surrey Posts: 1455 |
Sorry being a tart, what colour are they ? And price ? It's good to be back from the dark side
DC110 -2012 Black with black hood and black x-tech FFRR 4.2 vogue Renault traffic auto PT crusier convertible Laika x700 Motorhome |
14th May 2013 8:27pm |
big steve Member Since: 24 Dec 2009 Location: hertfordshire Posts: 2456 |
They graphite grey and price depends on what diameter and length you want
Steve 2015 2.2 tdci hardtop xs 3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P hybrid turbo in build -done ready to fit ashcroft atb in transfer box 6 speed auto in build |
14th May 2013 8:29pm |
11mm 125ft ideal for warn or goodwinch lowlife winches £250 plus postage
14th May 2013 9:20pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 7730 |
125ft of 11mm on a lowline winch - you sure it will fit? goldfish extended drum maybe but on a std lowline? Cheers
James 110 XS Utility 130 Puma Station wagon/camper (in the making) 90 Puma Hardtop |
14th May 2013 10:04pm |
Well im sure mine has and it's a std drum although I will double check tomorrow
It may well be only 100ft but I'm putting 100ft 12mm on the front Steve 2015 2.2 tdci hardtop xs 3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P hybrid turbo in build -done ready to fit ashcroft atb in transfer box 6 speed auto in build |
14th May 2013 10:22pm |
normally 80ft of 11mm on a lowline, 100ft will go on a large drum Goldfish
so 8274 front then? we normally run 125ft of 12mm on ext drums on 8274s. Cheers James 110 XS Utility 130 Puma Station wagon/camper (in the making) 90 Puma Hardtop |
15th May 2013 7:20am |
No a lowline up front 2015 2.2 tdci hardtop xs
15th May 2013 7:51am |
100ft of 12mm on a lowline, thats good going, std drum? whats bunching like on use? Cheers
15th May 2013 8:30am |
All seems ok I don't know wheather it's just me but the thought of using the thicker rope just give me more reassurance 2015 2.2 tdci hardtop xs
15th May 2013 8:39am |
dont forget the thicker the rope the larger the min bend rad! so in fact a smaller dia rope is better at acute pulls! Cheers
15th May 2013 10:10am |
Yes I know what you mean jst 2015 2.2 tdci hardtop xs
15th May 2013 12:38pm |
willy eckerslike Member Since: 15 Jun 2009 Location: North yorks Posts: 1789 |
What is the difference in min radius bend between a 10mm and 12mm rope? Is it not 3 times the diameter on a fixed pin and 8 times diameter on a sheave.
so 6mm difference between 10mm and 12mm on a fixed pin. Original Member Pie n Pea Club. 110 HCPU Tipper |
15th May 2013 2:15pm |
Sorry I stand corrected on my rope on my car its 100ft 11mm
Sorry jst Although still going to try a 12mm on front Steve 2015 2.2 tdci hardtop xs 3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P hybrid turbo in build -done ready to fit ashcroft atb in transfer box 6 speed auto in build |
15th May 2013 9:05pm |
off roaders gen to work on 7x factor for teaching etc. its not so much the difference at the ideal bend radius, more so the fact you have it on a tighter than x7 radi when through 90deg out a fairlead (although large rad fairleads help (delta - tek - for example)) and the difference there that a smaller rope will take it better. ropes that fail dont usually fail at this point, they fail soon after on a 'normal' pull in the area where the bend would of been at max load from my experience Cheers James 110 XS Utility 130 Puma Station wagon/camper (in the making) 90 Puma Hardtop |
15th May 2013 9:38pm |
