Home > Puma (Tdci) > Extra "bar" in front on 110 XS?
eutek
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Stornoway Grey
Hi all,
I was looking at two different 110 XS, a Puma and a Td5. I noticed that the Puma has what appears to be an extra "bar" fitted to the front of the truck, underneath and slightly behind the front bumper.
None of the Td5 110's I looked at had this, nor did the 110 SW.
Does that extra bit have a name or purpose, or am I just seeing things?
Post #17310 27th Oct 2009 5:52pm
bob neville
Pure guess - anti roll bar ?
All 110XS's, well new ones ! have them fitted (I think !)
Bob
Post #17313 27th Oct 2009 6:29pm
Grockle
If it's the tubular bar I'm sure it's to protect the steering damper and track rod etc 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #17315 27th Oct 2009 6:34pm
parktag
France 2008 Defender 130 Puma 2.4 HCPU Zermatt Silver
It's to protect the steering. Almost all military vehicles have them fitted. There not very expensive. 130 crew cab
98 V8 Disco
Post #17326 27th Oct 2009 7:52pm
mse
Underride protection bar £60ish Mike
Post #17327 27th Oct 2009 7:55pm
Mad Cow
England 2007 Defender 90 Puma 2.4 HT Zermatt Silver
They used to be standard equipment on Defenders, no doubt deleted to save cost.
I fitted one of these instead:
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  MAD COW
2007 90 Hard Top - 2009 BMW F800GS - 2002 CCM 604E Dual Sport
Project90
Post #17356 27th Oct 2009 11:03pm
mse
I have a steering guard but had a underride protection bar on the last - to be honest, both served a purpose. The steering guard gives you a big skid - i really hammered the bar with some force. Mike
Post #17360 28th Oct 2009 12:30am
eutek
Thanks guys - it is indeed the tubular bar. I wasn't sure if it was anti-sway or served some other purpose.
Post #17374 28th Oct 2009 9:27am
Caterham
Mad Cow.I like you're protection.  Is it a LR original item or something else?what sort of money are those and did you fit it yourself (was it straight forward / take long) ?thanks
Post #17376 28th Oct 2009 9:44am
TallPaul
caterham - I think they just bolt on. If you open and LR mag there are lots of adverts, either steel or alu, one or 3 piece, with/without recovery eyes.
By the way Mad Cow, I can still read your reg in that image (and your house number on the bin!)
Post #17394 28th Oct 2009 11:46am
Mad Cow
It's a Rebel 4x4 "Aluminium Steering Guard (10mm brackets)" the side brackets are steel with an aluminium plate. It is listed at £96 although I paid £90 at the Billing Show in the Summer.
Very easy to fit, bolt each side plate on, the offside rear uses steering mount (the standard bolt being plenty long enough) and they supply a new bolt for the rear nearside. The front mounts use the existing tie down brackets, you just remove the plates (the guard has proper recovery points that can be obviously be used to secure the vehicle).
One problem I found was the rear mounts for the plate were too far apart even though the holes were slotted. I just added a flat washer between the side plates and the chassis on each bolt (and each side) and that was sufficient to bring the plates close enough together to fit nicely.
And on the basis that a picture is worth a thousand words:
Project90
Post #17465 29th Oct 2009 9:16pm
Mad Cow
Thanks for spotting that but not anymore you can't Very Happy MAD COW
Project90
Post #17466 29th Oct 2009 9:18pm
parktag wrote:
It's to protect the steering. . There not very expensive.
They're not very good either! i used to have one, and bent it right back onto the steering damper (they're only thin walled tube)
OK, they are better than nothing but if you're willing to spend £60 on one, you might as well add another £20 and get a proper bash plate.
the UK Wolf XD's have a solid plate as standard (as did the camels and G4's)
Post #17467 29th Oct 2009 10:03pm
Mad Cow
The standard guard on my old 90 was similarly rather battered when I got it. Took it off last month for access to change the steering drop arm and couldn't ever get it to fit again because it was so out of line. Didn't bother when I part exchanged it.
It's still sitting in the back garden waiting for my next trip to the dump Very Happy MAD COW
Project90
Post #17469 29th Oct 2009 10:17pm
alantd
I too fitted one. I think I got it from John Craddock in the end but here's another example from FirstFour . It's pretty cheap at £75 although mine was Aluminium and around £95. One that started out as a 2.4 TDCi 110 XS
Post #17474 29th Oct 2009 11:39pm
