Home > Puma (Tdci) > fuel tank breather relocation.
YORKSHIRELAD
Hi all. I've just unclipped my breather from it's location under the wheel arch and shoved it behind the light cover. Do I have to fasten it to anything behind there or is it o.k just hanging about. Cheers,
Richard 1963 Series 2A truck cab
2008 110 SW
Post #17035 22nd Oct 2009 1:04pm
spudfan
Ireland
Why not add an extension and run it along the chassis rail then up to the bulk head. That is what I did to mine. 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #17037 22nd Oct 2009 2:23pm
YORKSHIRELAD
Cheers for that Spud 1963 Series 2A truck cab
2008 110 SW
Post #17054 22nd Oct 2009 5:29pm
alantd
You should be all right just tucking it under the plastic flap.
Obviously an extension is a better long-term solution but moving it is a good start. One that started out as a 2.4 TDCi 110 XS
Post #17096 23rd Oct 2009 11:31am
CapeLandy
South Africa
I also extended mine into the cab where my dual battery wires come in and have had no fumes or ill effects, only peace of mind Smile Puma 110 - gone
Series III 1973 - going strong
Post #17129 24th Oct 2009 6:24am
totoD110
Re: fuel tank breather relocation.
Richard
hi Richard!
which specific wheel arc is it located so i can relocate mine also...
Thanks in advance
Post #17131 24th Oct 2009 6:33am
YORKSHIRELAD
Richard[/quote]
hi Richard!
Thanks in advance[/quote]
Hi. It's under the rear left wheel arch as you look at it from the back. Thumbs Up
2008 110 SW
Post #17134 24th Oct 2009 8:44am
alantd
totoD110 wrote:
Richard
hi Richard!
Thanks in advance
Yup, rear LHS. It looks like a 6mm tube that is bent over 180 deg with a 2" radius on the bend. At the back of the wheel arch. One that started out as a 2.4 TDCi 110 XS
Post #17159 24th Oct 2009 9:21pm
one_iota
Australia 2008 Defender 110 Puma 2.4 SW Alpine White
alantd wrote:
totoD110 wrote:
Richard
hi Richard!
Thanks in advance
Mine being a 10MY had it on the drivers side (RHS) above the tank near the chassis rail:
This I think was an attempt by LR to get it out of the spray from the rear wheel.
Mine has been extended subequently during the course of the installation of a 40 litre auxiliary fuel tank behind the rear wheel to a higher position. Mahn
'08 Defender 110
ex '95 Disco 300 Tdi
www.aulro.com
Post #17161 24th Oct 2009 9:38pm
3WHouse
Russia 2007 Defender 110 Puma 2.4 SW Java Black
Lift upward..))
 Def`s 90 & 110 Monochrome.
You can go fast i can go anywhere.))
http://www.offroadpower.ru/
Post #17164 24th Oct 2009 9:54pm
totoD110
Thanks I found mine at the LHS. Thumbs Up
Post #17174 25th Oct 2009 7:52am
sasha2001
Russia 2008 Defender 110 Puma 2.4 CSW Tonga Green
3WHouse wrote:
Lift upward..))
love your pictures, does your club got out much
Cheers Simon
Post #17195 25th Oct 2009 7:00pm
GR110P
Greece
Is it ok to relocate the fuel tank breather to the bulk head ?
I can do it ,easy ,but maybe its too far away from the tank?
Is it functional ?
Post #17430 29th Oct 2009 6:53am
spudfan
Ireland
Extended mine along the chassis rail and up to the bulkhead over a year ago and everything has been fine. 1982 88" 2.25 diesel
Post #17457 29th Oct 2009 6:31pm
sasha2001
Is it functional ?
Also extended to the front bulkhead and no problems
Post #17459 29th Oct 2009 7:15pm
