Home > In Car Electronics > iPhone 5 compatible Head Unit search. |
iPints Member Since: 15 Jun 2012 Location: SC Posts: 294 |
Had a little search this morning and cant find any head unit that is compatible with the iPhone 5.....
I know it will bluetooth to almost any of the bluetooth systems but i quite fancy using the headunit to charge the iPhone too.......any thought or advice.... |
31st Mar 2013 11:28am |
rustyboxx Member Since: 08 Oct 2012 Location: Poole Posts: 548 |
My Kenwood has a USB connection and I can charge my iPhone 5 from that using the sync cable and still have audio streaming over Bluetooth.
Finding a head unit with an integral lightning connector is gonna be pretty tough I reckon. |
31st Mar 2013 12:41pm |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6510 |
Don't most iPod compatible headunits use the standard iPod cable now, so the lightning cable supplied with the phone is used to connect it up? 1988 90 Td5 NAS soft top
2015 D90 XS SW |
31st Mar 2013 12:52pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19677 |
I wouldn't bargain on it Martin although I guess different bands vary. Most as far as I know use the 30pin plug but seeing as I don't have either a ultra modern HU not iPhone 5 I can't be sure. Personally I've not seen anything to do with the lightning plugs yet on any I.C.E. system but happy to be proved wrong.
There is these available though: http://www.ebay.co.uk/itm/New-8-Pin-Lightn...19da5a9fd4 Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧 |
31st Mar 2013 12:58pm |
Steve, agree that older HUs (like the one I have in my 90) use their own connectors/adapters to the wide 30-pin iPod/iPhone connector. I was under the impression that (most of?) the newer ones used a USB port for iPod/iPhone
Using an adapter in the car is clunky, have to it with mine to charge the iPhone and it constantly detaches 1988 90 Td5 NAS soft top 2015 D90 XS SW |
31st Mar 2013 1:04pm |
Cakey Member Since: 19 Feb 2013 Location: Cheshire Posts: 468 |
My alpine unit that came with the car, works and charges iPhone 5.
Just use the USB to lightning cable |
31st Mar 2013 1:15pm |
tookaphotoof Member Since: 18 Mar 2013 Location: dordrecht Posts: 1279 |
My unit somehow does give an error when I plug my iPhone 5 in.
31st Mar 2013 1:40pm |
What is odd with the alpine, the phone works for calls etc via Bluetooth.
For music and charging you have to select source USB . |
31st Mar 2013 1:54pm |
Most HU's have a female USB socket and in my case video jack and audio jack too. These then plug into the Kenwood specific IP300 Ipod Audio Video cable which then connects to the iPod / device.
This will be useful: Kenwood iPod / iPhone Compatibility List Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧 |
31st Mar 2013 3:40pm |
barbel jim Member Since: 12 Dec 2012 Location: Northants Posts: 1412 |
my Alpine headunit works fine with the dedicated Ipod lead. Just put and adapter on taking it down to the smaller size plug for the Iphone 5. Can play standard Ipod as well. Not sure if it dose everything it should as Yes got an Iphone 5 but don't know how that works All the gear no idea
31st Mar 2013 4:19pm |
RobKeay Member Since: 19 Jul 2009 Location: Stafford Posts: 1568 |
My parrot works ok with my iphone 5.
31st Mar 2013 5:27pm |
Since Apple allowed 3rd partys to read digital audio over the USB then headunits have gone down the USB socket only, not requiring the audio/video separately.
See the Kenwood iP101 cable, etc 1988 90 Td5 NAS soft top 2015 D90 XS SW |
31st Mar 2013 6:15pm |
davew Member Since: 02 Jan 2012 Location: North Yorkshire Posts: 888 |
iPhone 5 works fine with all my JVC head units (one in each car of different ages/models). The oldest one has a JVC iPhone lead that you have to use but it works fine with the adaptor. The other two just use the USB cable so the normal charging/syncing cable works.
Full control over music playing from the head unit (skipping tracks, track/artist display etc...) as well as charging. I chose the JVC in the first place as they were the only supplier publicly claiming 100% compatibility with iPhone for both music playback and hands free use. http://www.yorkshireoffroadclub.net/ |
31st Mar 2013 6:55pm |
double post http://www.yorkshireoffroadclub.net/
31st Mar 2013 6:56pm |
