![]() | Home > Td5 > Defender Cruise Control The guide they didn't want you 2 see |
VeeTee Member Since: 06 Mar 2011 Location: Somewhere Posts: 1512 ![]() ![]() |
It is even much more simple!
Just some wire and switches, and use the build-in cruise control in the ECU. ![]() The plug on top is the black plug on the ECU under the seat. The pins on the ECU will be connected the following way: Pin 10 - Ignition +12V Pin 11 - Switch 1 (Set function) Pin 15 - ignition +12V Pin 17 - Switch 2 (Resume function) Pin 19 - is only mentioned, so you can connect here the available TD5 tachometer, not used for the cruise control. The cruise control works by supplying ignition +12V to pin 10/15 permanently and the functions are activated by supplying the same temporary to pin 11 or 17. For getting the ignition switched +12V (Z�ndplus 15), use the green/white cable at the temperature or fuel gauge in the dash. Put two switches on the dash and run a long cable to the ECU. Cheers, Vincent 1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
Sorry, missed that... ![]() 1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
chinnus Member Since: 24 Aug 2012 Location: UK Posts: 119 ![]() ![]() |
This is what I have done thus far... pretty much the bones of it are there....
will put some more pictures in it tomorrow and update it but for the eager ones have a look at this https://skydrive.live.com/?cid=3824FB2FC74...E9EA%21107 |
yobbie Member Since: 15 Nov 2010 Location: Isle of Wight Posts: 713 ![]() ![]() ![]() |
Have replied to your pm chinnus but it hasn't left my outbox.
