![]() | Home > Puma (Tdci) > Here the sketch of EGR valve garket....... |
ALL DIMENSION ARE IN MILLIMETERS
![]() Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() Last edited by dgardel on 16th Sep 2009 8:53pm. Edited 1 time in total |
expedition Member Since: 11 Sep 2009 Location: Vercelli-ITALY Posts: 75 ![]() ![]() ![]() |
It is a. ..? You say you make a plug from the form, as was done on the TD5?
![]() I believe this is to use it? Vale 110 Td4 MY07 "E" Keswick Green |
on td5 are different (different EGR valve form factor and pilot solution)
Tim_NZ Member Since: 05 May 2008 Location: Australia Posts: 177 ![]() ![]() |
Thanks dgardel!!! That will make life eaiser!
Cheers, Tim |
