Home > In Car Electronics > £7.99 Aerial upgrade.
Tiger
Okay so my aerial is bent and although I quite fancy an Entreq ones the wallet can't manage it at the moment and I don't like the Rubber Ducky aerials so I came across this in Maplins and thought I'd give it a go.
£7.99 Maplins Car Aerial
Coated in Shrink Wrap to get rid of chrome and shiney plastic and to give uniform look
Bent
Snap off
Put threaded piece in and crimp
Screw on new aerial and push down tight to home
20mins max, £7.99 and no wiring! Radio works fine. Thumbs Up
Will take a better photo in the light.
Post #206308 28th Jan 2013 8:14pm
XS Pete
England 2011 Defender 90 Puma 2.4 XS CSW Stornoway Grey
Cool! I assume the threaded piece you crimped on is a good tight fit, or it could part company at speed.
Pete
Post #206315 28th Jan 2013 8:19pm
SGH
Sweet Thumbs Up
Post #206316 28th Jan 2013 8:20pm
GUM97
Nice! Can't go wrong for £7.99 Thumbs Up An engine to TDi for!
Post #206318 28th Jan 2013 8:21pm
Tiger
It's a Land Rover, if at least one part doesn't fall off per journey then it's not working as it should.
*Yes, it's very tight, hence the ratchet crimpers
Post #206320 28th Jan 2013 8:28pm
Tiger
Day light photo, I'm quite chuffed with this. It looks okay I think.
Post #206583 29th Jan 2013 8:11pm
x-isle
Awesome, I love a good bodgejob!
I might give this a go on the weekend as mine works ok, but it doesn't go all the way down and get's stuck. Craig Rogers
2007 Puma 110 XS
2011 Evoque Coupe Dynamic Lux
www.craigrogers.photography
Post #206850 30th Jan 2013 5:31pm
x-isle
Tiger!..... Bow down
Just did mine the same.
I opted for a VW replacement for £3.85 Laughing
http://www.ebay.co.uk/itm/270955002855?ssP...1497.l2649
Works a treat! Perfect reception! Craig Rogers
2007 Puma 110 XS
Post #207433 1st Feb 2013 7:58pm
Norm4n
Is that a straight replacement or is some jiggery pokery required?
Post #207438 1st Feb 2013 8:12pm
Tiger
£3.85 ! - you win
Post #207439 1st Feb 2013 8:12pm
x-isle
It really is simple. As Tiger explained, cut/snap the original off at the last section then screw the threaded bar into the remaining aerial left over. Crimp it with cutters/pliers/crimp tool and screw the new aerial in. Push down flush.
To be honest, the thread took so well inside the original aerial that it didn't need to the crimped but did it anyway. Checked the radio and FM, MW and LW all work perfect. Craig Rogers
2007 Puma 110 XS
Post #207449 1st Feb 2013 8:33pm
Thud
United Kingdom 2008 Defender 90 Puma 2.4 SW Zermatt Silver
That looks a bit Heath Robinson to me. You lot are a load of cheapskates.
Post #207458 1st Feb 2013 8:58pm
Tiger
Yorkshire and proud
Post #207459 1st Feb 2013 8:59pm
x-isle
Welsh and proud Craig Rogers
2007 Puma 110 XS
Post #207464 1st Feb 2013 9:06pm
