Home > Technical > TD5 defender headlight failure - HELP PLEASE
Page 1 of 4 1234>
Kev stephenson
United Kingdom 2005 Defender 110 Td5 XS CSW Java Black
I've got a 2005 defender 110 T5 XS and on friday 50 miles into a 250 mile drive in the dark my headlights failed. I still have sidelights and the pull to flash works on the main beam but I have no dipped beam or high beam on pushing the stalk.
1. The switch itself feel firm enough and causes the relay to click on moving the switch to sidelights and again to dipped beam.
2. I have run a multimeter over the relay and can find 1 wire which is live with ignition on and switch off, this then goes to 2 showing 12v at sidelight position and 3 showing 12v at dipped beam position. I assume this is the input to the relay which causes the click. I can't understand why when the relay clicks I don't get an additional 12v signal (output) on one of the other wires.
3. There is 0v at both the fuses associated with the dipped beam headlights. The fuses are intact.
Can anyone provide a detailed description pin by pin for this relay?
Where is the live feed to this relay from? I can't seem to figure out how 1 relay can run 2 fuses and 2 lights seperately unless the feed to the relay is unfused or comes from something which isn't marked correctly/clearly.
Any help on this would be much appreciated. Not being able to drive the thing between 9am and 3.30pm is driving me mad.
Thanks in advance
Kev 2005 110 TD5 XS running Alive Stage 1 and a bit and other toys
1996 130 300TDi chip truck for tree surgery business
Post #194444 17th Dec 2012 9:16pm
Dave-H
Dispite all your findings, don't dis-count the switch ... its the usual suspect 95% of the time Confused Guns and Landrovers .... anything else is irrelevant.
Post #194449 17th Dec 2012 9:19pm
Switch, or check the loom along the wing length to the bulkhead, I've found broken wires near the bulkhead before now.
Post #194452 17th Dec 2012 9:27pm
Kev stephenson
I have tested the switch and it seems it only switches the relay, which it is doing so I can't see why it would be at fault. I could be wrong but not sure how and don't want to just throw money at the problem replacing bits until I eventually replace the right one, hence asking on here.
Regarding the broken wire can anyone tell me roughly where it runs or provide a wiring diagram so I can bell it out. There is no roon in the back of the dash to just go feeling each wire in the hope of finding a break.
Thanks 2005 110 TD5 XS running Alive Stage 1 and a bit and other toys
Post #194458 17th Dec 2012 9:35pm
VeeTee
Netherlands
Most likely the switch failure. See my post earlier: http://www.defender2.net/forum/topic16451-7.html
If you measure the voltage at the contacts with a multimeter, there is no load and you may well measure 12V then. But when you apply a load (lamps on) and there is a contact resistance, the voltage will drop dramatically. Some times the contact points of the switch look OK and by measuring with a multimeter seem OK, but in reality the switch has gone wrong. Cheers, Vincent
MySite
Post #194469 17th Dec 2012 9:49pm
Kev stephenson
What does the relay do then if the switch is full load? 2005 110 TD5 XS running Alive Stage 1 and a bit and other toys
Post #194477 17th Dec 2012 10:06pm
VeeTee
Netherlands
According to the electrical scheme, there is no relay between switch and headlamps. I drive a 300Tdi (1996), not a TD5, so I do not have hands on experience, but I'm pretty sure this the same in both models.
Note: This scheme is for MY2002, the wiring diagram for a 300 Tdi is here. Cheers, Vincent
MySite
Post #194492 17th Dec 2012 10:33pm
Dave-H
As Vee said, switching is direct, no relay [Thats why an often recommended mod for better/brighter headlights is to rewire with better cable and via relay's] Wink
Relay your hearing is probably down to the switch being kaput, so the current finds it own path elsewhere [as power will always take path of least resistance]
Trust us .. its the switch, it always is ... Guns and Landrovers .... anything else is irrelevant.
Post #194493 17th Dec 2012 10:37pm
Retroanaconda
There is a headlamp relay. Connector C0282, behind the fusebox panel on the bulkhead. I believe it only serves to enable/disable the headlamps with the ignition though. I.e. The headlamps can only be on with ignition on.
There's also the dim-dip relay (if fitted) which has an effect on headlight function.
Post #194502 17th Dec 2012 10:49pm
Kev stephenson
There is a pinkish relay on the left hand end of the bank of relays which are behind the clocks. This clicks when the switch is moved. I will fit a new switch and report back with results. 2005 110 TD5 XS running Alive Stage 1 and a bit and other toys
Post #194508 17th Dec 2012 10:54pm
Retroanaconda
That pink one is the dim-dip relay. That can cause issues. There is a replacement "dummy" relay available which does away with it (dim-dip no longer a requirement in UK law):
http://www.brit-car.co.uk/product.php?xProd=138745
To test the theory, you could try removing it and bridging the two blue-red wires together. If the headlamps then work then it's this dim-dip thing that's the problem.
Here's a photo showing which pins to bridge to test it:
Post #194510 17th Dec 2012 11:00pm
davew
It'll be the switch, the main dip/full one. the contact that supplies power to the two positions goes high resistance causing it to fail. High beam "flash" gets it's power via a different route. If you are handy with a soldering iron you can normally get it working again by soldering the brass post to the copper track it's supposed to make contact with... but watch for the plastic support melting !
The blue wire is the supply into the switch, you can see the repair I did to fix it although I later replaced the assembly just in case and have kept the repaired one as a spare.
To test it check to see if there is power (with the lights on) at the blue wire and on the copper strip itself. If you partially slide the blue wire off the post you'll find you have power on the brass post but not on the copper track it is riveted to. This seems to be the common point of failure for this switch.
The main switch can also fail but normally you can feel that that isn't right and it sounds as if the dim dip relay is firing which suggests the main switch is working OK. http://www.yorkshireoffroadclub.net/
Post #194516 17th Dec 2012 11:13pm
Kev stephenson
And the winner this weeks of 'diagnose that fault' is DaveW.
In my case however the plastic which holds the bit that you have soldered has melted meaning the flat piece of copper with the post on was sitting a few mm closer to the steering wheel and not making contact as it should to allow the headlights to work
A 10 minute job to change once I managed to get the steering wheel off (45 minutes!!!)
To all those that said it WILL be the switch........not always the case!!
Thanks again
Post #194930 19th Dec 2012 5:08pm
VeeTee
Netherlands
Thanks again
Kev
??? Confused Confused Dit you read my earlier post:
Quote:
The melting light switch is a common failure, caused by poor design. All current is going through the switch contacts, after some time the switch will fail due to melting of the plastic which is holding the copper contacts. This *will* happen sooner (if driving much with lights on or towing) or later.
I told you it would melt... So the winner is... Rolling with laughter Laughing Cheers, Vincent
MySite
Post #194951 19th Dec 2012 6:31pm
Dave-H
Er - that IS the switch Rolling Eyes Guns and Landrovers .... anything else is irrelevant.
Post #194976 19th Dec 2012 8:03pm
Page 1 of 4 1234>
