Home > Technical > Light switch power load
Page 1 of 4 1234>
VeeTee
Netherlands
The melting light switch is a common failure, caused by poor design. All current is going through the switch contacts, after some time the switch will fail due to melting of the plastic which is holding the copper contacts. This *will* happen sooner (if driving much with lights on or towing) or later.
The solution is the use relays to switch the lights, then only the small current to operate the relais flows through the switch.
You can make this from ordinary relais but you can also buy complete sets with connectors on, plug and play Smile , like I bought such a complete set in Sweden:
 Cheers, Vincent
MySite
Post #186231 18th Nov 2012 11:51pm
Inigo
United Kingdom 2012 Defender 110 Puma 2.2 USW Orkney Grey
I was hoping to find an off the shelf wiring kit to add relays and also include wiring to an extra set of spots at the front. I had no luck and so have bought all the cables, relays and connectors to build up a loom myself. My plan was to use the existing wiring to the headlamps to take the trigger for the relay so that I didn't hack about the standard wiring and it could be removable.
I got lots of info from here: http://www.danielsternlighting.com/tech/relays/relays.html
Currently psyching myself up to actually start this project.
Post #186235 19th Nov 2012 12:09am
WelshGas
Wales 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
VeeTee, according to my calculator that wiring harness is about £20 GBP.
Can anyone confirm my currency conversion. Whistle
If that is correct it is hardly worthwhile buying the bits to make a DIY harness.
BUT, does anyone know how we can buy one in UK? The site is ALL in Swedish and only seems to post internally in Sweden. Big Cry Big Cry LANDYWATCH
Neighbourhood Watch for Land Rover Owners
http://www.landywatch.co.uk/smf2/index.php
Post #186248 19th Nov 2012 7:50am
VeeTee
Netherlands
That is correct. I payed about € 20 for it (3 years ago). It is a very nic plug and play solution wich has the advantage that you can unpllug and remove it any time to have the original situation, so no wire cuts or soldering etc.
The Swedish webshop did not post anymore to abroad, so I posted a question for help on a Dutch-Sweden forum and some there was so kind to buy it for me and send to to me.
But I know a Dutch guy here who recently started a shop for this sort of mods, may be he sends to abroad?
Give it a try here Cheers, Vincent
MySite
Post #186250 19th Nov 2012 8:52am
mobilecentre
blackwolf wrote:
Don't forget that the headlights use different contacts in the switch to the side/panel lights. Max current on any contacts will therefore be 2x55W.
Remember also that if you have a trailer it will potentially add another 3 to 7 or so 5W tail/marker lights.
There is a single power feed in which then contacts the first position for side lights and then bridges both positions when dip is engaged.
Post #186254 19th Nov 2012 9:33am
mobilecentre
There are a few guides about relaying up headlights knocking about online on various other LR fourms.
Post #186255 19th Nov 2012 9:34am
Yes indeed, so there is one pair of contacts for the side/tail/etc and another pair for the headlights.
The dip switch is, in my experience, more prone to melting than the light switch.
It is a high impedance connection between the contact points which generates the heat, rather than the current flowing through the metal parts. The cleaner the contacts the less likely there is to be a problem. Arcing across the contacts (which is of course inevitable on a DC system) tends to corrode and oxidise the contacts resutling in poor connectivity and hence heat. The more the contacts are switched the worse this will, and since generally the dip switch is operated more than the on/off switch in many cases it will give up first.
Post #186267 19th Nov 2012 11:06am
WelshGas
Well I've registered with the site that VeeTee gave a link to. Using Google Translate I've managed quite well, but although the UK comes up on their country list, in Dutch, I cannot select a delivery method so have emailed them.
Hi mobile centre, yes I have a pdf document on how to do it, but I'm not that handy with a soldering iron and by the time I bought everything it would probably cost 2 or 3 times as much. Cannot find any suppliers of a ready made "plug & play" loom in the UK - strange. But never mind, we'll see what happens. Whistle LANDYWATCH
Post #186440 19th Nov 2012 9:20pm
WelshGas
Just heard back from Martin regarding purchase and delivery of the Defender headlight relay loom. They can deliver to UK but there was a fault on the website so all looks good. Thumbs Up LANDYWATCH
Post #186451 19th Nov 2012 10:05pm
VeeTee
Netherlands
Thumbs Up Cheers, Vincent
MySite
Post #186453 19th Nov 2012 10:08pm
WelshGas
Update.
Websit fixed and Relay Loom ordered and paid for. 50.50 Euro delivered.
Thanks VeeTee. LANDYWATCH
Post #186476 19th Nov 2012 11:01pm
Mo Murphy
What a useful website Smile
50 Shades of Pennine Grey
Post #186683 20th Nov 2012 8:36pm
kmac
WelshGas wrote:
Update.
Thanks VeeTee.
Was that the cost for the realy loom and replacement headlamp switch or just the relay loom and delivery to UK?
Post #186907 21st Nov 2012 5:28pm
WelshGas
Purchase and delivery of wiring loom only to South Wales. My switch is fine, at the moment. This is a preventative action. Thumbs Up LANDYWATCH
Post #186976 21st Nov 2012 8:40pm
kmac
Okay thanks
Post #186987 21st Nov 2012 9:03pm
Page 1 of 4 1234>
