![]() | Home > Wheels & Tyres > Wheel carrier and bumperette combi |
MartinK Member Since: 02 Mar 2011 Location: Silverdale (Lancashire/Cumbria Border) Posts: 2665 ![]() ![]() ![]() |
Thanks
![]() Those bumperettes do indeed look very similar to the Safari ones... Any chance of a close-up of the lower mounting, and how it works with rthe bumperettes? The swing-away is on my shopping list too ![]() |
lrMike Member Since: 26 Feb 2010 Location: Athens Posts: 177 ![]() ![]() |
Will send a close up tomorrow Martin.
Sorry for the small delay Martin. Please find below the photos that I took where the attaching points are shown. The bottom bracket of the wheel carrier is attached on the screws which hold the bodywork to the rear crossmember while the rear bumperette sits lower and is attached directly on the free holes of the rear crossmember. Last photo shows the top bracket which is attached directly on the bodywork using a reinforced plate on the back for extra strength. ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
Fantastic, Thanks Mike
![]() I have Safari Equipe bumperettes, and i like them a lot. Already saved a rear corner from a bit of damage ![]() At some point soon-ish I'll get a swing-away, but I don't want to lose the bumperettes - yours looks an excellent solution. Thanks very much for taking the time to post ![]() |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10383 ![]() ![]() |
I want a swing away, just like this but with a jerry can holder and a picnic basket tray...
Looks great Mike ![]() |
I am glad I helped with the photos and thank you for your kind comments.
I also had the same questions about the combination but Brendan was always there to help me choose. Greeni the jerry can holder would be a great idea but is it allowed to carry fuel like this? |
HardCharger Member Since: 03 Mar 2013 Location: Manila Posts: 756 ![]() ![]() ![]() |
Nice kit you have there lrMike! Thinking that may be the way to go for me. How's it holding up so far?
I tried looking but could not find it, may I have the Safari website? |
jomara Member Since: 26 Oct 2009 Location: Lanarkshire Posts: 1790 ![]() ![]() ![]() |
Here you go Hardcharger
![]() http://www.safari-equip.co.uk/index.php 2014 110 2.2TDCi XS Station wagon 1971 Bowler Tomcat 88 4.2 V8 Auto 2022 110 D250 XS Edition - Gone 2024 110 D250 X-Dynamic HSE |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17705 ![]() ![]() ![]() |
There'd be "issues" with that in the UK on an RHD vehicle due to the rear fog light being obscured by the jack. I guess you'd have to relocate the fog light somewhere (must be on or to the offside of the centreline, of course).
A nice set-up on an LHD vehicle though. ![]() |
There are several available options for wheel carrier/bumperette combinations, including reworking some bumperettes to fit if necessary.
http://www.defender2.net/forum/topic25541....bumperette If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! Last edited by K9F on 30th Jan 2015 6:25pm. Edited 1 time in total |
![]() Click image to enlarge I've had my safari equip bumperettes remodeled (�30 from a local blacksmith) to remove part of the inner bracket of the bumperette, and reduce the depth of the bracket by 5mm. You can see the LH bumperette still fitted. The swing-away is a wonderful stainless one from Brendan at 4x4overlander ![]() I'll post a pic later when I get chance (Defender's away tucked up in a garage) Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) |
There can always be issues when people buy aftermarket kit from different manufacturers in are they compatible with each other.
Nakatanenga are planning on doing rear bumperettes to work with their wheel carrier. Safari Equip had to modify their rear bumperettes when they introduced their single pivot wheel carrier. Personally I am not a big fan of carrying a high lift jack outside the vehicle. Now BW point about obscuring the rear fog light does raise some questions and interpretations. A rear fog light is an obligatory light under the Vehicle Lighting regulations so has to be operational etc. However under VLR
Now a rear fog light is not a rear position light so where does it stand legally if obscured??? I do not know, I carry our high lift jack inside the vehicle. Brendan PS We tend to carry both wheel carriers in stock ![]() |
Chris86 Member Since: 15 Jul 2014 Location: South Yorks Posts: 798 ![]() ![]() ![]() |
I need to sort this out on our 110 too- we have the same problem!
Summer job I think- I'll repair the door first Chris |
Thanks jomara! ![]() |
