Home > Puma (Tdci) > Vacuum Pump - Which one do I have?
Phoenix90
United Kingdom 2007 Defender 110 Puma 2.4 USW Stornoway Grey
Im slowly working through all the 'common' faults the puma suffers with to try and reduce the chance of me suffering from them on a trip!
Is there any way to identify what vacuum pump I have? It's a 2007 Puma and it seems that vac pump failure on that model is relatively common so if I still have the old one i'd rather replace it before it becomes a problem! I don't have the full history so don't know if it has been replaced.
Thanks
Post #182075 4th Nov 2012 8:08pm
I don't think there's any way to tell the old type and new type apart, until the old type fails and starts squirting oil over the underside of the bonnet.
On an 07 you would have had the original single seal type fitted from new. If the underside of the bonnet is oil stained, it (the vac pump not the bonnet!) has probably been replaced.
Replacing the vac pump is a simple job and to be honest I wouldn't bother unless it starts leaking.
Post #182226 5th Nov 2012 12:56pm
Regard
South Africa 2011 Defender 110 Puma 2.4 X-Tech LE Orkney Grey
Yip!
And from what I have heard the new ones fail just as much as the old ones.....
We had a 110 with a failed vac pump on our most recent trip in northen Botswana/Zambia. We fixed it with Pratley Steel Thumbs Up
Rather cary a spare with. It takes 3 bolts and one pipe to loosen and Bob's your uncle!
Post #182264 5th Nov 2012 2:49pm
you could always pm the previous owner Shocked
Post #182274 5th Nov 2012 3:34pm
You could but he wouldn't know it it was original or had been replaced, except not whilst he had it Rolling Eyes
Post #182284 5th Nov 2012 4:26pm
Phoenix90
Thanks all, i'll carry one and a set of seals as spares Thumbs Up
Post #182406 5th Nov 2012 9:20pm
big steve
United Kingdom 2015 Defender 90 Puma 2.2 HT Montalcino Red
I'm pretty certain but may be wrong but its only the seal that needs replacing the pump doesn't actually fail does it ?
Steve Neutral 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P
hybrid turbo in build -done ready to fit
ashcroft atb in transfer box
6 speed auto in build
Post #182416 5th Nov 2012 9:45pm
Phoenix90
Steve Neutral
That would make sense, but all the topics I have read on it say replace the pump and the seal together Question
Post #182458 5th Nov 2012 11:06pm
I don't think it's possible to remove/refit the pulley, so the seal can't be replaced.
Post #182469 5th Nov 2012 11:43pm
yaho
Poland 2007 Defender 90 Puma 2.4 SW Keswick Green
I have heard the new ones leak too - but in that case one has to exchange seal only (on old ones it was whole pump).
Maybe someone here know definite answer Question Janusz
www.yahodeville.com
Post #182496 6th Nov 2012 8:29am
big steve
I thought that the gasket is the problem it leaks and obviously gets to the pulley and spins it everywhere Hense there was a new gasket that superseded the old one with one less hole or something like that
But we all no what thought did
Steve 2015 2.2 tdci hardtop xs
Post #182518 6th Nov 2012 10:10am
I don't think that the gasket has ever been the problem. The early pumps had a single-lip oil seal on the shaft (behind the pulley) and once crud got in and damaged the seal, would leak onto the pulley, which then flung it all over the place. Quite spectacular really! Also of course once the belt gets oily it is likely to fail, with the consequent loss of fdrive to the alternator, water pump, PAS, etc. Not good.
The later pumps have a double lip seal, so simplistically the outer lip keeps the crud out, and the inner lip keeps the oil in.
On the early pumps the pulley cannot be removed without destroying it, and I thought the new type were the same in this respect. I have a spare (new type) on the shelf, if I remember I will have a look to see.
I have never heard of any gasket failures.
The pump is very easy to replace, but it does help if the viscous fan can be removed (removing the fan makes it easier to remove the drive belt, but is not essential). Removing the fan is not particularly easy unless you have a suitable tool to hold the fan hub, as well as a 32mm spanner.
Post #182522 6th Nov 2012 10:18am
