Home > Maintenance & Modifications > Muddy LANDY. Bigger tires my TRY.
aage
Iceland 2011 Defender 110 Puma 2.4 DCPU Alpine White
What I did to prevent the landy to become all dirty when driving in mud with wider tires are as shown on these photos.
I put on a 285 75 16 tires on a 8 inch wide rim ( from paddock ) . The car did get all dirty driving it like that because the tires are wider than the fender flares , especially where the flares meet the body at bottom. the top of the flares do cover the with of the tire.
I installed a 3mm aluminum boards both side , then I bought a vines plates to use as a mud flaps. The vines is stiff enough go force the fender flares out at the bottom making it wide enough to cover the tires. Connected it to the aluminum boards and its like you see on the photos.
It works very good and now I can drive in mud without the car to become to muddy Smile.
Gonna close the gap in the aft of the rear tires to later.
[/img][/code]
Excuse my english, not my native language Wink.
Hope it be of help for someone regarding MUDPROOFING the landy Wink http://www.defender2.net/gallery/index.php?cat=13451
Post #180589 31st Oct 2012 11:13am
aage
AUTO SPELLING :-(
Should be VINIL plates , not wine plates Laughing http://www.defender2.net/gallery/index.php?cat=13451
Post #180591 31st Oct 2012 11:14am
WelshGas
Wales 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
Sure you don't mean " VINYL " Whistle LANDYWATCH
Neighbourhood Watch for Land Rover Owners
http://www.landywatch.co.uk/smf2/index.php
Post #180647 31st Oct 2012 2:46pm
aage
Well ;-)
What should I call these Mudflaps of mine then Shocked Laughing
Plastic ? http://www.defender2.net/gallery/index.php?cat=13451
Post #180689 31st Oct 2012 4:51pm
defender4
United Kingdom 2007 Defender 90 Puma 2.4 XS CSW Java Black
Never mind all that, it's a very practical and elegant solution.
Post #180708 31st Oct 2012 6:03pm
WelshGas
If you made a mud flap that extended UPWARDS as well as downwards then when bolted to the mudflap bracket, but further outboard than the normal mudflap, it would extend up into the wheel arch and if the same width or greater could be moulded into the wheel arch brow. Use of the mudflap extension bracket by Entreq could assist .
Or, using a slightly thinner material overlaying the mudflap and extending upward and outward into the wheel arch could do the same, the aim being to extend the wheel arch brow down onto the mudflap Thumbs Up LANDYWATCH
Post #180717 31st Oct 2012 6:36pm
aage
ys
It is what I´m doing in front. The mudflap extend up much higher than seen and then it connects to the inner fender with some black silicon and few screws making it a closed space.
Gonna do the same in rear. Move the rear mudflap much closer to the rear tire. Then extend it to close that space around the rear tire.
I will post some photos when I have it done. http://www.defender2.net/gallery/index.php?cat=13451
Post #180792 31st Oct 2012 10:02pm
