![]() | Home > Puma (Tdci) > Hazard lamp light |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4780 ![]() ![]() |
Just checked. The warning triangle on the hazard light switch does light up. The headlight adjuster knob does not light up but the numbers on the lefthand side of it do. 1982 88" 2.25 diesel
22900013A Member Since: 23 Dec 2010 Location: Oxfordshire Posts: 3150 ![]() ![]() ![]() |
Hmmph, looks like I have a blown bulb and a missing bulb then. So what do I need to get from Halfords, besides a special screwdriver to take the dash centre panel out?
Remembered this thread - may be of use:
http://www.defender2.net/forum/topic12482....zard+light Made me run outside and check mine ![]() But shout it at them in German because life is also terrifying and confusing... |
Think it one of those Torx screwdriver heads. There's a thread on this site about removing the centre dash. Once you remove the screws it's a matter of prising out the centre dash. Have not had to do it myself so hopefully someone with some experience of actually removing it will be along to give you the do's and don'ts.
Hopefully someone will tell you what bulb to get so you can have it instock before you remove the dash. The tdi used to use small plug in type capless bulbs, 12V 3W, but I don't know about the Puma. 1982 88" 2.25 diesel 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
How funny, it has now fixed itself...typical Landrover electrics eh...
Do you have to specify this optional extra? ![]() 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
In case someone needs to buy the little bulb for this hazard lights switch, read the following which PaulMc was good enough to let me know when I had this little bulb burn out a while ago. And LR could not find the replacement for it in its database, so I ordered a few from rimmerbros. Below are the details, one day you will need them
![]() As for the switch's bulb, it's not listed in Microcat for the 2002-2006, or 2007 -> Defenders (so most dealers tell you it's not replaceable and try to get you to buy a complete new switch). It is replaceable, it's listed for the 300Tdi Discovery 1 Hazard Warning Lights Switch (which is essentially the same switch, but vertical instead of horizontal), its part number is - STC1205 - BULB & HOLDER ASSEMBLY, CLEAR http://www.rimmerbros.co.uk/Item--i-STC1205 You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
I thought it was a standard fit since at least the 1960s, my IIA has the same foible. |
Merlin Member Since: 30 Oct 2010 Location: Newmarket Posts: 981 ![]() ![]() |
Just got mine, when you say "little bulb", you're right. It's so small that for a minute I thought they had forgotton to put anything in the box.
Merlin |
