![]() | Home > Technical > scan gauge 2 fuel consumption |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3664 ![]() ![]() ![]() |
Took the 90 for a drive with the scan gauge connected and it is showing between 4 and 14mpg which is clearly incorrect anyone on here with one know how to re-calibrate it
thanks in advance Rob DEFENDER 90 TDCI XS, I hope everyone is well and your land rovers make you happy |
familymad Member Since: 13 Dec 2011 Location: Bucks Posts: 3481 ![]() ![]() ![]() |
Hope it's wrong or I'm out! 1951 80" S1 2.0
1995 110 300TDI 1995 90 300TDI |
Phil VM2.5 Member Since: 28 Mar 2012 Location: Limelette Posts: 196 ![]() ![]() ![]() |
hi,
I am also using the scangauge and also do not think that fuel consumption is correct ! but no idea what to do ! As late as possible, I will use it for code of defect Philippe current : defender 110 sw 2.2 puma 2012 and 230.000km today and again my Range Rover VM2.5 engine from 1992 and 528.000km today. One ten 1988 to 1992 1987 BMW GS80 One Ten from 1984 to 1987 One Ten from 1983 to 1984 Serie 3 109 from 1980 to 1983 from 1974 Jeep CJ3B and CJ6 |
Tony Member Since: 13 Mar 2012 Location: West Yorkshire Posts: 72 ![]() ![]() ![]() |
Hi,
I've just fitted one this morning so will be going through the fuel calibration process next time I fill the tank up. How did you calibrate it initially - did you go through the process in the instructions when you filled the tank? Cheers ![]() |
hi,
yes, I did as descripted ... I wonder if the filling procedure is something to do with instant mpg I am also not doing same road all the time, it can be highway , city, .... Phil current : defender 110 sw 2.2 puma 2012 and 230.000km today and again my Range Rover VM2.5 engine from 1992 and 528.000km today. One ten 1988 to 1992 1987 BMW GS80 One Ten from 1984 to 1987 One Ten from 1983 to 1984 Serie 3 109 from 1980 to 1983 from 1974 Jeep CJ3B and CJ6 |
o4dn Member Since: 08 Jan 2010 Location: South West Posts: 567 ![]() ![]() ![]() |
Did you set the engine size and diesel type according to the manual (Basic Setup Parameters, page 11)?
MPG accuracy is not perfect but nowhere as a far as 14MPG, at least in my case, and it improves with subsequent fill-ups if you take the time to adjust the volumes of fuel to help calibrate the scangauge (Calibrating the ScanGauge, page 20) |
tatra805 Member Since: 16 Aug 2011 Location: Dolany Posts: 436 ![]() ![]() ![]() |
Mine is spot on every time.
I never used a calibration procedure, just put the parameters right first time it is powered up(engine size, tank size and diesel type) and at each fillup log the liters put in. Since then it is working a perfect. The only nasty thing is that when idling the consumption goes up and you need to drive a bit to get it down. The further you are in a tank/ the more fillups you have logged, the quicker it gets back to normal values after idling and the less variation you will notice / the more precise short trips become. ![]() |
all thanks for the responses I think I will do a reset and start again see what happens DEFENDER 90 TDCI XS,
lrmaniac Member Since: 04 Feb 2010 Location: Lisboa Posts: 764 ![]() ![]() ![]() |
Topic Hijack...or not
Had my fuel breather pipe broken for a while, need to reset the fuel consumptions and can't find out how... ![]() How do I reset the scangauge? I did read the manual but did not find... Regards Joao '10 Land Rover Defender 110 CC '08 BMW F800GS '64 SIIA Forward Control '69 SIIA 109 ZA CKD _____________________________________________ You have the right to remain silent. Anything you say will be misquoted, then used against you. |
Hi
I've reseted my scangauge but can't seem to reset the litres on fillup... I've had a problem during the summer, on the fuel breather pipe and was unable to fillup the tank for a few months till get it sorted... Now on fillup the other day the scangauge states I've filled uo 450L! ![]() Now, the only way to tell the scangauge the right amount of fuell in the tank is to let my finger on the < key till it reaches 65 wich I recon it would take me about half an hour? Can't I reset this item? Regards Joao '10 Land Rover Defender 110 CC '08 BMW F800GS '64 SIIA Forward Control '69 SIIA 109 ZA CKD _____________________________________________ You have the right to remain silent. Anything you say will be misquoted, then used against you. |
