Home > Maintenance & Modifications > SVX style rear turn signals from Mobilecentre - now fitted
ericvv
Placed the order with Tim from Mobilecentre a few weeks ago and package arrived within 2 days. Two clear LED turnsignals (to replace the standard SVX versions which still remained incandescent bulb fitted), 6 gaskets so that I could also install the gaskets on the standard SVX LED rear/stop lights, rear fog light and reverse light. Land Rover does not bother fitting these gaskets in the factory, it is not a real necessity, but a nice little upgrade, further a new flasher relay to replace the original which is necessary to avoid the flashing frequency to increase due to the LED's having much lower wattage, and 12 stainless steel screws to replace all the original ones. In hindsight must admit that it seems that the OEM ones on my SVX were stainless steel after all, contrary to what was said here on the forum.
The entire replacement was fully plug and play, and a good occasion to get all rear lights off, cleaned behind, extra Dinitrolled, all electrical contacts WD-40'd, etc.
The result is perfect, the indicators now when not on have exactly the same appearance as the brake/rear position light, and when the turn signal is on, the LED pattern is an exact match with those brake/rear position lights, and last but not least, the indicator flashes are stronger and with the known crisp on/off typical for LED's.
Nice upgrade, and very good service from TIM Thumbs Up
Here are some pictures of "before 'n' after".......... No, not that one Rolling Eyes
Before
After Thumbs Up
Before
After Thumbs Up
 You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #164116 24th Aug 2012 9:59am
Porny
Site Sponsor
Re: SVX style rear turn signals from Mobilecentre - now fitt
You can put the indicator in the standard LR position now...
Land Rover only moved the indicator into the inner positions for aesthetics - i.e because the incandescent lamps didn't match the other LED's.
Ian IRB
The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers.
www.IRBdevelopments.com
www.facebook.com/irbdevelopments
www.integrated316.com
www.facebook.com/integrated316
Post #164133 24th Aug 2012 11:45am
ericvv
Ian
Thanks Ian, had not thought of that, but was a quicky to sort that one out. Done now as you can see below Thumbs Up Thumbs Up
Post #164147 24th Aug 2012 2:02pm
mobilecentre
Glad you are happy and sorry about the delay whilst we were at Billing
Tim
Post #164871 28th Aug 2012 12:50pm
