Home > Puma (Tdci) > Puma 2.2 Turbo Hose
Page 1 of 6 123456>
Doublecabdefender
United Kingdom 2012 Defender 110 Puma 2.2 XS DCPU Orkney Grey
Puma 2.2 Turbo Hose
Last week took our usual hols up to the Lakes from Norfolk. Very Happy First decent trip in the new DCPU 2.2, all going spankingly well until half way up the M6. Big bang, followed by enthusiastic whooshing, to cut a long story short the hose that comes from the turbo, offside under the larger air intake pipe had blown off.
Land Rover Assistance chap assured me that it had never been put on correctly in the first place, and promptly refitted it. One hundred miles further, same result Shocked Managed to limp into Eskdale to our cottage. Again LR Assistance came out and announced that the fitter on the M6 hadn't tightened the jubilee clip correctly Evil or Very Mad
It also seems that on the inside edge of the jubilee clip there are two nodules which are meant to help grip the pipe. According to LR these are a menace because the have the effect of cutting into the pipe and causing it to split! Which has happened to mine.
So a quick call to Coniston LR to order a new pipe, Ah 'No Sir, very sorry, this is a known issue and no pipes available in UK at the moment due to a high demand'. Great....... so the rest of the week, I am driving around waiting for it to come off again, it did move and does need to be re-tightened periodically. As LR says, the pipe is under huge pressure when under load, and probably needs 2 x clips instead of one. Part now on order back in Norfolk, no due date as yet Big Cry
The reason for the post is that it might be prudent to check on your pipes, so to speak, before you are stranded. No pipe, zero power, zero movement.
Simon 2012 Defender 110 DCPU XS 2.2 Puma Orkney Grey
''I can resist everything except temptation. ''
Post #136236 2nd Apr 2012 12:32pm
Zagato
Shocked Thanks for that Thumbs Up
Not heard of it being a problem though even with the heavy towing lads Confused Maybe just 2.2 related!
Post #136238 2nd Apr 2012 12:39pm
ZeDefender
...and so it begins...
Looks like we'll have lots of new 2.2 members after all Twisted Evil Tell someone you love them today because life is short.
Post #136243 2nd Apr 2012 12:58pm
Zagato
Laughing
Could be wrong but have a feeling they repositioned the Turbo on the 2.2 to squeeze the DPF in! Why that would make any difference I don't know - useful eh! Whistle Rolling Eyes
Post #136246 2nd Apr 2012 1:02pm
excossack
Heat buildup causing the rubber pipe to go soft? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #136251 2nd Apr 2012 1:13pm
ZeDefender
Check your battery connectors as well (playing the Devil's advocate today)... Tell someone you love them today because life is short.
Post #136266 2nd Apr 2012 1:57pm
Axel
Germany 2012 Defender 90 Puma 2.2 SW Keswick Green
Happened to me as well .... hose slipped off after approx. 1,500 miles .... has also happened to several other MY12 owners that I know ... Seems to be a kind of general bug ..... Best Regards,
Axel
Post #136267 2nd Apr 2012 2:00pm
Lorryman100
On 2009 builds as well, caught this in time.
Post #136275 2nd Apr 2012 2:36pm
Doublecabdefender
Yup, that's the offending little chap Twisted Evil 2012 Defender 110 DCPU XS 2.2 Puma Orkney Grey
Post #136277 2nd Apr 2012 2:44pm
Allan
Australia 2008 Defender 110 Puma 2.4 SVX Station Wagon Santorini Black
This seems a common problem on the 2.4 also. Someone at land Rover needs to ead his vegimite for breakfast. Rolling with laughter Rolling with laughter Rolling with laughter
Allan
Post #136286 2nd Apr 2012 3:47pm
ZeDefender
... that's "Marmite" over here my Antipodean friend Laughing Tell someone you love them today because life is short.
Post #136288 2nd Apr 2012 3:59pm
ZeDefender
... but certainly either would do, together with a bit of brains mixed in (yeuch)
Thumbs Up Tell someone you love them today because life is short.
Post #136290 2nd Apr 2012 4:01pm
Zagato
Oh better keep an eye on it then Thumbs Up Will be heavy towing soon Shocked
Post #136311 2nd Apr 2012 5:23pm
spudfan
Ireland
You could put some heavy duty duct tape on the hose beneath the hoseclip and then tighten the clip without damaging the hose. You could also repair the hose split temporarily with the duct tape. I've got stuff here called "Gorilla Tape" and it is really strong. 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #136323 2nd Apr 2012 5:42pm
Doublecabdefender
The split is on the inside of the pipe, not the outside. I believe the pressure exerted on the pipe is immense when under load, tape might protect the external surface but I don't think that is the issue. I think its a poor design, LR gave me a call today and said they are trying to source a much wider jubilee clip which should almost fill the indent in the turbo outlet. Hopefully eliminating any form of slippage. 2012 Defender 110 DCPU XS 2.2 Puma Orkney Grey
Post #136360 2nd Apr 2012 8:28pm
Page 1 of 6 123456>
