Home > Puma (Tdci) > How long has your Gearbox and Transfer box lasted!
Zagato
Going from feedback from a couple of previous threads it would be interesting to see how much of an issue there is with the TDCi gearbox and transfer box.
How long has your gearbox lasted and what type of use has it had?
How long has your transfer box lasted and what type of use has it had?
Post #132898 20th Mar 2012 7:30pm
bob neville
As we now know, my gearbox/transfer box have now lasted 20,000 miles, it is the bit that joins them that gave up after 20K.
Clutch, about one every 6K so far Shocked
70% road use, 30% off road, some very heavy. No towing.
2013 Defender 90 CSW - sold
Post #132912 20th Mar 2012 8:25pm
WelshGas
Wales 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
24k miles. No problems with gearbox/transfer box or clutch. 90% on road hi-speed if possible don't like to be last in queue, 10% gentle off-road. LANDYWATCH
Neighbourhood Watch for Land Rover Owners
http://www.landywatch.co.uk/smf2/index.php
Post #132933 20th Mar 2012 9:12pm
AdrianCR
2016 Defender 110 Puma 2.4 XS CSW Scotia Grey
2008MY 65k miles one cluth, genuine Tbox,gearbox 90%very heavy off road.
Post #132938 20th Mar 2012 9:22pm
double cab happy
England 2007 Defender 110 Puma 2.4 DCPU Java Black
58K miles all original except for the oil, no problems,
had a word with opie about gear box oil when I was doing the transfer box oil as Tbox is every 48K but Gbox is 120K say land rover, opie recommend gear box oil every 40K?
food for thought
Mark
Post #132960 20th Mar 2012 9:49pm
kingofthesparks
Location: Very close to Watford gap services , northants
United Kingdom 2012 Defender 90 Puma 2.2 HT Fuji White
241,000 miles , no problems here, and yes I always pull away in second unless uphill or towing . Very Happy
Post #132961 20th Mar 2012 9:53pm
cinstone
England 2015 Defender 90 Puma 2.2 XS CSW Keswick Green
43k+ miles. All original.
Chris. http://shropshirelandrovers.freeforums.org
2015 Defender 90 XS SW & Helen, 1964 IIa. Previously 2012 Defender 90 XS SW & 2008 90 XS SW.
Previous LR's: Michael, my 2008 Defender 90 XS SW.
Machinas oportet intrare non capsicum annuum faveo
Post #132975 20th Mar 2012 10:51pm
rossy
Zag just change your gearbox oil - you know you want to ! Smile (just think of all that swarf - its in there grinding down yer splines Crying or Very sad )
Post #133009 21st Mar 2012 12:09am
ericvv
Just under 40.000 miles, all on-road, infrequent long highway trips at 80mph, but main use is half city, half intercity. Gentle with the mechanics, but all original, gear- and transfer box, original clutch (has had the occasional light rattle at idle for a while, but that seems to have disappeared now. In two weeks time plan to change for the first time both gear- and transfer box oils (engine oil/filter every 4000miles), and also will change for the first time the diffs oils. Sofar all works a treat, touch wood will stay like that Thumbs Up You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #133030 21st Mar 2012 6:19am
Naks
Gearbox: 2yrs, 29,000km, no tough offroad use
T-box: original --
Post #133086 21st Mar 2012 12:56pm
NinetyTD4
Wales 2012 Defender 90 Other SW Keswick Green
Mine is only 8k and nothing but smooth. A friends '08 TD4 has come from Africa recently and that machine runs now at 125k with first gear/transfer boxes. Never forget: cars have owner, Landrover have field service personnel.
Post #133106 21st Mar 2012 2:08pm
coming up 24 months old, just over 10k miles and no problems. going in this week to have transfer box, gear box and axle oils changed.. will be watching the output
95% on road, did some off road in France and Switzerland
no problems at all Thumbs Up
Post #133221 21st Mar 2012 9:36pm
Utility110
New transfer box at 4k although I'm not sure it was right from new. Took it in to LR with a nasty clattering after long distance and then coasting to junctions. Service manager assumed it was loose clutch plate fixings but then called me back later kept the car for a few days.
minimal off road before, lots since with no problems.
Post #133261 21st Mar 2012 10:58pm
mudrut
United Kingdom 2008 Defender 110 Puma 2.4 USW Stornoway Grey
I wonder if it would be helpful to put the model (90/110 and body type) and even tyre size/type, so we could see if the relative weight of the vehicle or loading on the transmission affects owner's experience?
Anyway, my vital statistics:
2008 110 Utility 54,000 miles often heavily loaded. Daily driving, long road trips, off road use - all original
2009 110 Double Cab 24,000 miles use as above.
Both vehicles are usually shod with 285/75R16 BFG KM2 although they sometimes have 285/75R16 Mickey Thompson ATZ
Interestingly, my 2001 110 did a gearbox at 50,000 miles. That truck was driven 'unsympathetically' off-road though Whistle
regards
Ian
Post #133320 22nd Mar 2012 9:14am
'07' plate DC, used daily including off-road, usually laden near GVW, coming up to 100k miles, on original gearbox and transfer box with no issues from either.
Several other driveline issues (front diff, rear halfshafts) and early-type clutch replaced with later type.
Main dealer did once advise I needed a new t-box due to backlash, but it was actually the front diff not the t-box, and I wonder how many other Puma 'gearbox' issues are in fact caused by other driveline components.
Overall I rate a good MT82 as the best Landrover gearbox since LR fitted synchro to 1st and 2nd gear; I'd certainly rather have an MT82 than an R380 any day.
Post #133326 22nd Mar 2012 9:29am
