Home > Maintenance & Modifications > Which Bumperettes?
Page 1 of 4 1234>
iruffell
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Zambezi Silver
Which Bumperettes?
I'm going to fit some bumperettes so that next time I reverse into a Clio I only damage the Clio Wink
I'm thinking of getting the Terrafirma ones as they will sort of match the tubular XS side step
Any thoughts?
Post #130714 12th Mar 2012 12:42pm
K9F
Re: Which Bumperettes?
iruffell wrote:
Any thoughts?
No thoughts of my own but I have chosen a few choice thoughts from others.....
http://www.defender2.net/forum/topic6033.h...umperettes
http://www.defender2.net/forum/topic10875....umperettes
http://www.defender2.net/forum/topic9077.h...umperettes
http://www.defender2.net/forum/topic8899.h...umperettes
http://www.defender2.net/forum/topic4422.h...umperettes
http://www.defender2.net/forum/topic1525.h...umperettes
http://www.defender2.net/forum/topic4273.h...umperettes If you go through life with your head in the sand....all people will see is an ar5e!!
Post #130715 12th Mar 2012 12:55pm
MartinK
Very pleased with my Safari Equip ones...
http://www.safari-equip.co.uk/index.php?page=64
Much nicer than the ebay cheapies, but without blowing the budget.
Galvanised & painted, looks great, comes with stainless screws. No drilling, 10 mins to fit.
Came from Brendan (aka "leeds") at 4x4 Overlander (a sponsor of the forum) - Brendan was a couple of quid cheaper than Safari Equip direct, and they were here within 48 hours Thumbs Up
I "tested" them when I reversed into a low-down sign Embarassed in a car-park a couple of days after fitting...worth their weight in gold. Defender 1, Sign 0 Thumbs Up
Handy to stand-up on to wash the roof of the Defender as well Thumbs Up Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #130762 12th Mar 2012 3:51pm
Zagato
Another vote for Safari Equip, you get what you pay for and they match the XS side steps nicely with matching chequer plate Thumbs Up Fancy things don't look right on a Defender IMHO, it's a utilitarian truck not a chav mobile Confused
Tested mine out also on a Fiesta two days after putting them on - Phew! (never backed into anything before either, It's fate as soon as you put them on Confused )
Post #130764 12th Mar 2012 3:56pm
iruffell
They don't show up on their website, do they still sell them?
Post #130768 12th Mar 2012 4:20pm
Zagato
Nothing shows up on Brendans website Rolling with laughter
If he hasn't got them you can order them directly from Safari Equip, nice bloke to chat to and deal with also Thumbs Up and don't forget to haggle, he's very hard to get down though, I didn't get much off, just postage I think in the end Whistle
Post #130770 12th Mar 2012 4:33pm
leeds
Yes we do still sell them.
Our website is like a Defender an ongoing project! Not made any easier with internet problems. Currently using a 3G dongle as have had 3 routers in last 2 months!.
Let me know if 90, 90 with mud flaps or 110. The Safari Equip ones work with their swing away wheel carriers.
Please note that not all after market bumperettes work with wheel carriers as some are too close to rear cross member/use same bolt holes as carriers.
Safari Equip ones are 6 mm steel, galvanised and then powder coated.
Brendan
Post #130771 12th Mar 2012 4:34pm
iruffell
Brendan
Thanks Brendan, what the cost of a set for 110 incl shipping?
Post #130772 12th Mar 2012 4:36pm
BigMike
The SE ones are very robust and a great bit of kit - slight word of caution though. They are galved then sprayed, not acid washed or blasted after the galv so if you get a pressure washer near them (like my LR dealer did) the paint will fly off faster than a hookers knickers. If I bought them again I'd buy a set without the chequer plate tops on and unpained, get them blasted then powder coated then rivet on the chequer tops.
Post #130781 12th Mar 2012 5:48pm
Zagato
Mine have been OK under the pressure washer, had them a year Confused Would be interesting to ask him if he is now etch priming the galv before he powder coats them! It will peel off in no time even without being pressure washed.
Post #130783 12th Mar 2012 5:58pm
BigMike
Not sure they're powder coated? I thought they were sprayed
Post #130792 12th Mar 2012 6:16pm
Zagato
Apologies, yes sprayed Thumbs Up
Post #130795 12th Mar 2012 6:27pm
leeds
Powder coated
Quote:
The Bumperetts protect the vulnerable corner of the Defender in off road conditions and act as a handy step. They are constructed from 6mm steel, galvanised and powder coated to ensure that they will last for many years no matter how much punishment you put them through. Fitted with a chequer plate top and supplied complete with all the fixings these bumperetts are designed to withstand serious impact.
Powder coating sticks to mild steel better then to galv. It also prefers nicely rounded edges to square edges. I can show examples of powder coating on bare mild steel peeling off from square cut edges (not SE gear) Powder coating on bare mild steel gives a smoother finish then on galv which has more of an orange peel finish.
It is swings and roundabouts, but if powder coating does come off they will not rust.
Cost for 110 is £153 plus £12 carriage if required. 90's are slightly cheaper
Brendan
Post #130796 12th Mar 2012 6:29pm
leeds
Deleted, sorry double post, blasted internet!
Brendan
Post #130797 12th Mar 2012 6:29pm
BigMike
Aesthetically it doesn't look great when the coating comes off in sheets though, despite not rusting. Powder coating does not stick at all well unless the surface is either blasted or significantly roughed up or etched in some way.
Post #130800 12th Mar 2012 6:57pm
Page 1 of 4 1234>
