Home > Puma (Tdci) > Just appeared on the GTR: SSM40851
Eduardo
Defender Front and Rear Propshaft Grease Points
Models : LD - Defender
Title: Defender Front and Rear Propshaft Grease Points
Last Modified: 30-MAR-2009 08:27
Category: Noise/ Vibration
Symptom: 703000 Vibration Concerns
Content Issue: Loose or missing front / rear propshaft grease nipples for Defender 07 MYonward vehicles.
Action: If any propshafts are identified where the grease nipples are missing, then the propshaft should be replaced. Any cases where the grease nipples are in place but loose should be torqued to 8Nm + 45degrees.
Cheers Eduardo
Post #9269 31st Mar 2009 5:04pm
Grockle
Thanks again for the tip off Ed, better check ours Thumbs Up 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #9274 31st Mar 2009 5:16pm
fekete
Nice one ED Thumbs Up NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #9275 31st Mar 2009 5:26pm
sasha2001
Russia 2008 Defender 110 Puma 2.4 CSW Tonga Green
Thanks!!
Post #9279 31st Mar 2009 7:24pm
silverpig
Top man Eduardo thanks again
Post #9280 31st Mar 2009 7:37pm
MK
Mine were loose. The probles is that the ones for the UJ“s are so hidden you need to rotate them to plug the grease pistol!
I“m wondering, how does LR realize about all these issues! The nipples hasn`t been a big issue on any forum! Puma 110" SW
Post #9281 31st Mar 2009 7:47pm
spudfan
Ireland
A mine of information as usual. Must check this weekend. Thanks Eduardo. Me thinks we should be subscribing to you! 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #9284 31st Mar 2009 9:42pm
Eduardo
Your welcome friends.
My subscriptions end in June (if I remember) and possibly I will suscribe again (It is worth its weight in gold).
If not, please can somebody take the flag?
Cheers! Eduardo
Post #9285 31st Mar 2009 9:52pm
Rob A
Brazil 2008 Defender 130 Puma 2.4 HCPU Alpine White
Cheers!
Thanks for the tip Ed
Just out of interest, how does the subscription work. Is it ridiculously expensive? 130 HCPU 2.4TDCi
110 300TDi
Post #9286 31st Mar 2009 10:37pm
Eduardo
Hi
You must be suscribe to the GTR.
Cost around US$300 per year for the internet access to the database including workshop manuals and all the bulletins. You can suscribe for a day, a week or a month.
Cheers Eduardo
Post #9289 31st Mar 2009 11:27pm
Rob A
Eduardo wrote:
Hi
Thanks Ed
Just one more question:
If you suscribe for a week (or even a day) can you download stuff from the GTTR. In other words copy all you want from the workshop manuals to your own computer? Very Happy
cheers
Rob 130 HCPU 2.4TDCi
110 300TDi
Post #9292 1st Apr 2009 3:22am
Bundubasher
South Africa 2007 Defender 110 Puma 2.4 SW Chawton White
Hi Rob. Yes you need a lot of paper and maybe a spare ink cartridge. Or you can use a free PDF file creator from pdfforge.net. Then instead of printing to your printer you print to the PDF file creator. Then save the PDF files in folders. You can then print them anytime you want.
Regards
Anthony
Post #9293 1st Apr 2009 6:59am
Fontuin
2008 Defender 110 Puma 2.4 SW Zambezi Silver
This, I suspect, is the cause of the infamous 'grooling' sound discussed elsewhere on the forum, LR have replaced a good number of rear diffs because of these missing grease points. I know mine(diff) was replaced.
Post #9294 1st Apr 2009 7:38am
nicks
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Alaska White
I spent many hours dowloading all the ws and electrical manuals and put them into pdfs on a day subscription. if anyone needs one give me a shout.
Post #9295 1st Apr 2009 8:18am
Eduardo
Hi there,
In fact a lot of us have donwloaded the GTR information in PDF (far better than have a lot of paper)to future reference
But the appareance of this new SSMs convince me to extend my subscription for 1 year.
Cheers Eduardo
Post #9305 1st Apr 2009 1:37pm
