![]() | Home > Maintenance & Modifications > Stopping my rear safari door from rattling |
Like what you have done there.
Those new door bolts make a big difference, although if those were the originals then they have done well for 9 years. |
I found my rattle was from the Landrover wheel carrier that had cracked in the corners so the wheel was wobbling and making the rubbing metal creek. Until I find a wheel carrier I like I just welded it up and welded some braces across the corners
Bushpig Member Since: 07 Nov 2013 Location: Risca, Wales Posts: 236 ![]() ![]() ![]() |
Did your kit come with support brackets for the mounts?
A LR dealership fitted mine without the supports and now the body has sheered. Argument with dealership begins...  |
