![]() | Home > Maintenance & Modifications > at 23:00 CET first Webasto (water) start-up!!!! |
1st attempt diesel line goes full......
2nd attempt.......... FIRE!!!!!!!!!! Great moment........ Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
get a video up!
to warm for a heater here! |
Sonic3d Member Since: 28 Jan 2008 Location: Ross on Wye Posts: 1505 ![]() ![]() ![]() |
Not all of Italy is hot ![]() |
gets flippin cold in the winter especially around the alps
![]() ![]() and congrats Daniele ... do you have photos of the installation ? did you use the entreq kit ? |
cobs Member Since: 12 Jun 2008 Location: North Yorkshire Posts: 336 ![]() ![]() ![]() |
Good man - enjoy a toasty warm Christmas
In my area it is normal to have -3, -6 C and my fatherl in love live closer to Cortina, into the Alps and last years we got -22 C......
Yes I used the entreq fitting kit (daily drivers one). Soon I'll post same photos Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
Daniele - so the daily drive webasto kit does not touch the entreq fuel cooler guard ?
BigRuss Member Since: 15 May 2010 Location: Norfolk Posts: 2785 ![]() ![]() ![]() |
we even got as lower temperatures of -20 C in feb this year in Aberdeen Russell
2011MY 110 XS USW Black |
Same here, and that was in Lancashire. A year ago it was -18 here at 7pm , and in the morning the outside gauage said it had been down to -21. Amazing really.
Still, didn't have any starting issues though. |
No touch areas, the heater is positioned completely "over" the crossmember, the entreq fuel cooler guard is fixed under (see the nut insert on crossmember), and it protects very well the heater from splash and dirt....... ![]() Click image to enlarge ![]() Click image to enlarge Installed also the by-pass valve for do not decrease the original cabin heater efficiency she the heater is switched off ![]() Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() ![]() IID Pro MV License |
Daniele, I guess for driving though you have a cap for the exhaust?
I love your set up and I know with your attention to detail it will be exactly right, but for me, for driving offroad there is no way I would put one under there. |
mermoto Member Since: 21 Sep 2011 Location: Essex Posts: 326 ![]() |
Nice job :thumbsup: Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
TJ101 Member Since: 30 May 2007 Location: Taunton Somerset Posts: 3750 ![]() ![]() ![]() |
I had a Webasto on a TD5 90 i had,,
Excellent bit of kit,, even had the remote control set up,, took 10 mins or so , was even connected to a hot water shower system ![]() Tried to justify the set up on the Puma,, but does not get the use to warrant the cost !! California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
The only cons is the lower position.... but I use my car for light off-rad The pros are the very short water pipes length so you have a very high heater efficiency and the accessibility for the future maintenance/checking operation. For the fuel tank accessibility I have done a "hole" directly on the rear floor and covered by a "strong" 3mm aluminium plate screwed with rivet nut inserts and foam gasket ![]() the ending results is similar to this one.... ![]() Click image to enlarge with this pickup ![]() Click image to enlarge ![]() Click image to enlarge For the kind of use that I do is the best compromise, I'm thinking about that a lot of months and finally........ Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License Last edited by dgardel on 24th Dec 2011 5:54pm. Edited 2 times in total |
